Adaptive layer thickness is a great feature in your product.
Is it possible to get something explained somewhere ?
Assume I’m using Linear interpolated mode for adaptive layer thickness.
What happens if I got a 2000ms 50 microns layer and adaptive(linear) using :
Min 10 microns, 1150 ms
Max 100 microns, 2500 ms
-> 1000 + 15 X
At 50 microns layer what will be used ?
The 50 microns base setting (2000) or the linear interpolated (1000+15x50 => 1750ms) ?
May it be possible to have a deterministic or array mode where we might define desired layer heights with exposure time ?
For example an array of 4 : 10microns (1000ms),30(1320ms) and 50(2000ms) and 100(2800)
Because I tested those and I know the results against the exposure and I don’t want computed values or mid steps like 37 microns layer.
Regards
