Drain holes are boleean operation,xhy not add more shape from user (trapeizoid,square …)
I am modeler and use assembly key for model with simple shape .
Another use of custom drain holes :we can stamp parts with an hole number easely identify parts
Add more drain hole pattern
sylus
Stamping and adding letters are on the list.
The drainage holes now are booleaned when you slice to 2d slices.
This is on purpose; since the actual boolean in 3d can lead to problems and strange results.
