So I’m currently using array single supports at roughly 1mm distance from each other. The shapes I’m supporting are angled enough that lattice supports aren’t quite right for it.
I’m wondering if there are any calculations I can run after running the single supports to create a ladder/ a lattice-like support structure (not including the tip)? My main reason for asking is because when I’m supporting 10-15mm from the build plate I can end up with very long, straight single supports that I think would be better as scaffolding instead.
