Elco,
Since the last couple of updates from both you and Ceality, the files still do load and print, but some of the print parameters don’t seem to push over to the printer. Meaning, I slice and export just fine, and the file loads just fine on the printer, but if I select “file parameters” on the printer UI, it does not load anything, so I have to use “printer parameters”. this applies only to the parameters that can be controlled on the machine interface screen like exposure time, base layers exposure time, base layer count, lift distance, rest time before and after, and motor speed. Other parameters, basically all the pre-processing and post-processing seem to work fine. So, everything under the tab “Movement & Exposure” is not pushing over or is been overwritten by the printer?
Please let me know if you need more information to look at this.
Thank you
Gonzalo
