When working with various blocks, each support information is sometimes different.
For example, when working with two blocks, the density of block A is 70% and block B is 80%.
If you suddenly try to edit block A again, and you forget whether the density is 70% or 80%, you have to change the number to set it again to 70%.
If you select each block, can’t you check the support generation information of that block?
