I do a lot of small prints and use different sized single supports for different areas. I like to have slightly thicker support for larger areas and slightly thinner supports for very small areas. Could we get a way to duplicate a single support profile to have 2 different single support sizes?
I primarily print Miniatures so having a 0.5mm and a 0.2mm single support is extremely key for me. I can spend 1-2hours plus per model adding and removing supports to get it in a place where it will cause the minimum amount of damage to the model itself to reduce the post-processing after print, so making the support smaller each time I place one makes this an even longer task.
Software like Chitubox has a large medium and small profile to choose from. Having a similar option to this would be great, or a way to change the size of the support on the fly would work also.
p.s I love this software. After the 30 day trial, I was hooked. But this would make my life MASSIVE amounts easier.
Thanks in advance
Sean
