- if we have some selected supports, pressing shift we select others but selected supports will be inverted. Need selection “only add without selection inversion” and “only deselect”.
 - please add select through all - all supports visible and invisible now selected with rectangle (now some supports doesn’s selects)
 - please add by doubleclick the same type of supports for changing their properties
 - if we delete some autogenerated supports with ctrl+del - it deletes some array of generated supports. Need some hotkey to delete just one entire support.
 - please add gizmo for endpoint of support. Now it’s possible just to scale it.
 - please add BACK view. There is now FRONT view only.
 - please add strengthener option for array supports (construction farm for single supports. Like at lattice support icon)
 - array support surface mode - please add option to add supports at edge of surface selection.
 - mirror supports - please add button that center plane on seleted part (max-min)/2
Thanks!
