Is there a way to saveguard support settings to be overwritten?
I noticed that some of my colleagues occasionally overwrite the production settings I’ve developed for our 3dprint department.
I did save them out as separate files, so i can restore them, but I would like to prevent the settings to be overwritten in the next time I boot up the program.
I’m fine with being able to change values on a case to case basis, but I do not want them to be permanently overwritten so the in next Formware session, you inadvertently start with the wrong settings.
the same applies for the print/resin settings, although there is far less risk there, cause ppl usually do not fiddle with the resin settings
From experience, i know this will end up with a production error, some day…
So it would be good to have the “default” settings protected…
