Can you add #time# tag to default name constructor?
Also, definition of a custom default folder would be very convenient.
Tomasz
Slice setup -> more tags and default folder
TomMartin
Hi Tom,
By coincidence I’ve already changed this logic in our development version.
For the slice folder it will save the last used folder automatically to the settings, unless a default slice folder is set in the configuration panel under ‘slicing’. (it would not save last used folder before)
The #time# i have not added but will do now.
I did add all Machine/PrintProfile parsing functionality to the name now. So you have the same tags as with for example generating a custom output text file.
TomMartin
Elco,
Wow! Great minds think alike :D. I am very excited to test new parsing in next Formware version. The solution you are testing would suit my needs perfectly. Though not critical, it would make the process so much convenient.
Best,
Tomasz
