I would like to suggest some new simple improvements:
Default printer with default profile selected always on program startup - without current “Choose mchaine & print profile” window; I can change it anytime from top-right menu in main window; this window is annoying.
File->Configuration; Machines->[some printer]->Print profiles: please add possibility to change profiles order.
When exporting to Anycubic_Photon file - export data (images) to some temporary directory and ask only for filename.
Rotating object in main window: default there is +/- 10 degrees in each axis. Please add:
- saving that values (after opening there is always 10 degrees),
- add dedicated buttons for rotate +/- 30/45/90 degrees.
Saving values in “Scale” window. Also - in “Scane to fixed size” there is “Scale X size to” instead of “…Z…” on third position. Aleo please save selected options like “Scale per direction” or “Scale Y and Z proportionally”.
Add closing that windows (like Rotate/Scale) with Esc button.
Add keyboard shortcuts to rotate, scale and move (like “R”, “S”, “M”) windows.
It will be very useful when size of object can be changed in “Object propeteries” tab (right side of main window). There are “Object size” values but they are read-only. It could be “Uniform scaling” (or add checkbox for that).
Navigating in main window - ideally: left button - rotate view, right - move view. But it would be enought when moving will be with middle button (and rotate with right, as it is now).
Please add keyboard shortcuts to “Display Mode” options (ex F5 - Shaded mesh, …, F8 - Transparent Parts).
Save settings from “Support generation” tabs.
Please change support generation alghoritm to NOT create arms that cross the object (markes as red after generation). Or add option to remove them at once.
Some strange feature that no-one have: every DLP printer have some resin container (that with FEP in bottom). It will be very useful when software will calculate…how much resin I’ll need for print (yes, this is now as Volume) - but in milimeters of resin depth in that container. To be honest - calculating volume each time is horrible; I know that from bottom to first fold in container there is ex. 5mm; software would say that I need 4.2 mm so I know that I need to add some resin. Simple and fast.
Settings of container size would be in Machine Options in menu (next to Build platform size). -
If tehre is possibility - in “Object properties” add text box for user comment.
Great software
