I would really appreciate to have a new method of support placement. Instead of showing entire supports, that covers up view from below, it would be nice to have displayed only circles in places where supports intersect with the object. I know there is a wireframe view, which helps a bit, but wireframe view does not indicate how big the support tip is - whether it goes beyond surface edge or not.
Support generation - supports as circles on object surface
So it would suffice to change the wire frame foot, which is currently a cross, into a circle?
TomMartin
Yes, I use wireframe view too, But sometimes I need to place a support as close to surface edge as possible. It is especially important with bottom surfaces tilted at a small angle.
