Text box to modify Printer Model
It would be nice to have in a future update, a parameter text box under Configuration - Machines allowing the user to change/modify the printer model along with the printer name. If the user tries to add their own printer or modify the parameters of an existing printer to use with a printer that’s not supported… without the correct printer model in the print file, the printer gives the error msg: “This model does not match the printer.”
hi,
sorry slow answer.
The challenge with this is that all printer manufacturers create their own strange file formats with their own rules of how to write strings of text to a binary format.
So we could make a textbox with a ‘type’ variable… that might make sense… but it will still be up on the implementation of the output file if it would work…
