Thank you for your rapid response…
they have stated it works well with their slicer and lychee…
i was planning on upgrading my transforms to a 13.6" 7k mono (as it is exact fit to my mono modded transforms, originally the rgb versions
), and from a few things i have read and discussed it says that it will need a vlare board; that the existing control board on the machine doesnt output the resolution…
Maybe you are aware if there is another control board that will play nice/integrate with existing transform components and run the 13.3 7k? I was wondering what control board the Photon M3 Max is using and if that would work? I think it is a chitu board also, friend said it has a different Z height… is there a way to change that? also i havent seen an available touch screen for that unit (not sure if it will work with the existing touchscreen)… from what i understand (at least on the vlare board) was that it was necessary to get a touchscreen to work with the board.
It no prob if you dont know, but figured you have a good understanding of the various machines.
any advice is appreciated/helpful…
Ultimately, I really like Formware and have had it for years… has been great and would love to use it to run all my machines. I advocate for formware whenever it is mentioned; especially due to the perpetual license… it is a rarity that is done anymore, and it is much appreciated, and shows the dedication to a good product over trying to make as much money as possible.
Thank you!
James
